When DomeLight of USD was imported in mayaUSD, it functioned as a light but not as a background
  • When DomeLight of USD was imported in mayaUSD, it functioned as a light but not as a background
    Invisibility is enabled as in vrayDomeLight.
    I understand that this can be handled with custom attributes, but there is no setting in USDDomeLight to not render the background, so I believe it is correct in the USD spec that the background is visible.
    What is the intent of the implementation here?​
    HTML Code:
    #usda 1.0
        metersPerUnit = 0.01
        upAxis = "Y"
    def DomeLight_1 "DomeLight_1"
        color3f inputs:shadow:color
        bool inputs:shadow:enable = 1
        ## Add the following code to render the background
        # custom int vray:LightDome_invisible = 0
    There's a "VRay Light Dome Invisible" attribute in the Extra Attributes of the duplicated USD VRayDomeLight, and it seems to work as expected. Is this not the case on your end?
      I think I can go with that! Thanks!
