Depth and Normals pass also contains invisible objects
  • Depth and Normals pass also contains invisible objects
    Hey Guys,
    i have a setup where one object is visible and all others are primary visible OFF in their vrayObjectProperties node....but they still show up in the normals and depth renderelement....is this the intended behauviour? (Motion blur is on)
    cheers
    Oli
    ...and if you need to change some things with the normals renderelement - maybe you can consider my wishlist post over here?
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
    This should be solved for recent builds.
