motion blur on realflow meshes
  • motion blur on realflow meshes
    I searched for info on this issue and found this post from last year
    Originally Posted by vlado
    Actually, you need to change the "Max. scene samples" from the Translator tab, not the moblur geometry samples - sorry about that. Otherwise V-Ray will always sample at frame boundaries which is where the real flow mesh changes vertices.
    Thanx Vlado. It works like a charm by doing that (had to change it to at least 3 for it to work).
    but it seems Max scene samples isnt in translator anymore. Can this still be found as a setting anywhere?
    Bryan
    This option has been completely removed. You can use the "geometry samples" in the motion blur settings for this. Or you can add a VRayObjectProperties to the mesh instance and specify motion blur samples for it only.
    Greetings,
    Vladimir Nedev
