Distributed Rendering animation trouble .. (NBuild 10868)
  • Distributed Rendering animation trouble .. (NBuild 10868)
    One of our users report that when rendering an animation he run in to problems when his FPS is set to 15 FPS in his Maya preferences.
    He reports that when rendering her get longer render times in his scene:
    1 min 6 sec per frame at 25 fps
    8 min per frame at 15 fps.
    He reports the same happen if he just animates a sphere, he gets similar problem.
    He tells me that if you set it to 15 FPS and batch render, it will not use the other machines in the DR pool.
    If you change it back to 25 FPS , it will use all machines in the DR pool!
    Please fix fast - he is about to kill me, cause he is missing his deadline.
    Kind regards
    Carsten Lind
    Senior 3D Artist, Maya software manager & Instructor
    LEGO System A/S
    Is it possible to get the scene anyways ( you can send it to me at vlado@chaosgroup.com )? This seems to work fine here for a simple scene.
      Hi vlado,
      I have asked him to send you a scene file..
      Kind regards
      Carsten Lind
      LEGO System A/S
        He has managed to find some workaround, and we will send a file to you guys as soon as he is done rendering his animation project.
        Kind regards
        Carsten Lind
        LEGO System A/S
