Issue Fog Environment, question..
  • Issue Fog Environment, question..
    I can't seem to scale the "Fogscatter"
    Where could i find the volume size, or can i change this in the .vrscene.
    Cause it seems to work only when i'm within a certain region of my object and my light.
    Thank you,
    O
    Can you explain a bit? I don't quite understand what you are trying to do.
      I'm making a "spotlight" or "vray rectangle light" and adding
      a "vray fog scatter volume" to my render settings.
      When i render in with my camera within a range of 40 cm of the object
      the render works,
      If i go further away with the camera lets say 1000 cm .
      (but even i think 100 cm away)
      The image will render black, cause the Lights / volumes diseappear.
      I remember one of you guys, telling me that the "vray fog scatter" has
      a size (aka coordinates), so my question is if i can make this bigger
      so the fog/ light don't disapear,
      Thank you, (hope this is more clear)
      O.
        Just curious if the problem was explained right
          Yes, but I'm having a difficulty to reproduce it - is it possible to get me a scene to vlado@chaosgroup.com
            I'll see if i can make something magical , thank you !
            send it in a few.
            O.
