VRayMtl Hardware Texture tab not found
  • VRayMtl Hardware Texture tab not found
    Not sure if this is a Maya specific error but sometimes when accessing the Hardware Texture tab on materials I get this error message from the script editor:
    // Error: file: C:/Program Files/Autodesk/Maya2011/scripts/AETemplates/AEhardwareTextureTemplate.mel line 827: Object 'VRayMtl_qualityMenu' not found. //
    Which ultimately means you can't turn on Hardware texturing so the material just displays "None".
    Reloading the scene however fixes this problem.
    Maya 2020/2022
    Win 10x64
    Vray 5
    I have had this error happen to me countless times too!
    Basically, if you change the name of the node from VRayMtl1 (or whatever it is by default), it will give you this error. You'll have to close and restart Maya again to make it go away for all other materials. To avoid it, this works: When making a new material (VrayMtl1), go to the Hardware texturing, set it to whatever you want it to be and after that, you can change the node name. It's absurd, but it works. Are you running Maya 2008 too? I haven't had this issue in Maya 2010 yet.
    /Bard
    www.hellobard.com
    Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
      Thanks for the tip! And FYI this is happening to me on 2011 (but I do remember this also on previous versions).
      Maya 2020/2022
      Win 10x64
      Vray 5
        Oh wow, I really hoped they had fixed it
        Maybe it's a V-Ray problem? What do you think, Vlado?
        /Bard
        www.hellobard.com
          I would say this is a Maya bug. I've seen it happen with Maya's materials as well. It happens when you have shapes(i.e. mesh nodes) in your scene that have exactly the same name. But I can't quite remember how you have to assign the materials to these in order the break it.
          Greetings,
          Vladimir Nedev
            No worries - Initially I thought it could be something to do with V-Ray because of the reference it was giving in the Script Editor but now I'll try and find a way to reproduce it and send in a bug report to ADSK, thanks guys.
            Cheers.
            Maya 2020/2022
            Win 10x64
            Vray 5
              Found the steps to reproduce, most definitely a Maya error.
              1 Create a cube.
              2 Instance it
              3 Create a Lambert
              4 Rename it Lambert2_name, change colour whatever
              5 Assign it to both cubes
              6 Open attribute editor's Material Tab
              7 Scroll down to the Hardware Texturing Rollout
              Maya will say // Error: Found no attribute match for "lambert2.color"
              Hellobard, help out by submitting a bug report if you add these steps in and this as this next line as the summary that would be great
              356316 Hardware Texture tab not found
              Maya 2020/2022
              Win 10x64
              Vray 5
