Vray Crash in Maya 2009 OSX
  • Vray Crash in Maya 2009 OSX
    Hello!
    I'm having a problem with Vray with Maya2009 on OSX (Leopard).
    I do not know if it's the performance of the machine or some configuration that I'm putting the Maya but still crashing.
    I'm using Irradiance map + Light Cache. But with very low settings and resolution 480x480p.
    When i let the GI off i can render the image, turn on the Irradiance map, I can render too, but when I turn on the Light Cache it closes the maya.
    I'll gonna try to take some SS of the settings and polygon count.
    I searched in the forum and read something about textures but all my textures are only 1024 pixels.
    I'm new to 3d and with the new Vray. If someone can help me?
    I'm using an iMac 2.8 with 4GB of RAM.
    It would be very helpful in debugging this problem if you could send us the scene. Or at least a stripped down version of it that still crashes.
    You can mail it to me at
    vladimir.nedev [at] chaosgroup [dot] com
    Greetings,
    Vladimir Nedev
      I think it will not be possible. The file is 70 mb in size.
      Its a complete scene of an apartment.
      This started happening when I put more objects in the scene.
      From this point of the image. http://www.flickr.com/photos/hedvy/4516528908/
      He is pulling all the memory of the machine and Dynamic Memory I put only to 1.5 gigabytes. And when the memory ends, he closes the Maya.
      I read something about giving the QMC problem with Light Cache. Is that it?
      Sorry if I'm not giving too much information or I am not knowing how to tell.
      Funny that it configured with 2 gigas in Dynamic Memory, it almost completes the LC but closes again. When I change to 1 gig it hangs at the beginning of the LC and stop.
        Some SS of the settings
          When Maya crashes, it should display a window that tells you that with an option to view the crash report; can you send this report to us?
            hey, just to chime in here, probably unrelated though.
            we just installed the latest nightly on a Mac w/2008 here today, and it was crashing the moment Vray was in use (opening hypershade). i found that the problem was some remnants from a previous install, I tracked down the vray files, deleted them all and re-installed with the latest nightly. that worked perfectly fine and it is no longer crashing. just a tip in case you've upgraded lately.
            /Bard
            www.hellobard.com
            Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
              The logs.
              www.boxshape.com.br/Log_problem_details.rtf
              www.boxshape.com.br/System_Configuration.rtf
              Thanks in advance.
              I gona try this too hellobard. But I remember I've had this same problem before installing the build of that to use vray fur.
                So, any reply plz?
                Thanks in advance
                  Please send us an e-mail to vray@cahosgroup.com so we could provide you with a nightly build to test.
                  Zdravko Keremidchiev
