proxis not rendering
  • proxis not rendering
    First time working with lots of proxis. I'm duplicating trees. I made the first type of tree duplicated as instance in maya from a vrmesh proxi, everything worked well (amazing to see how much polys you can render).
    Then I added the second tree type from a new proxi vrmesh. Now i duplicated it again with instances 300 times, and when i render, only the first ones show up, and the others just disappear ??!!
    (I have no RAm problem, using just 2GB for now and i have 6GB.)
    Searched the forum for such a problem, but couldn't find anything...
    thank's for any help !
    regards,
    Olivier
    www.mirage-cg.com
    I think it's resolved somewhat. I re-duplicated all the trees and now it works. I must have a instance duplicate error as i wat doing it with the three keys hotkey. That would mean that i did once a normal duplicate.... still i find strange that it didn't render, will have to check that...
    regards,
    www.mirage-cg.com
      You have to duplicate with upstream connections turned on. Turn that on in the options boxes.
