error writing file - Vray standalone
  • error writing file - Vray standalone
    I am doing a test render but am noticing an error on completion of the render.
    This is the command I am using
    vray -frames=2426-2426 -numThreads=1 -sceneFile=renderTest.vrscene -imgFile=renderTest
    This is the error.
    [2010/May/14|16:14:47] error: Cannot write output image file "renderTest": "error writing file"
    Is there a default location where vray renders the files, or must you specify the path when giving it the file name?
    Diego
    Hi Diego,
    You should set the extension of the image file. For example "renderTest.jpg"
    Tanya Metodieva
      Thank you Tanya I will try this
