high contrast flickering.
  • high contrast flickering.
    ok so perhaps the title is not 100 correct, but I dont know how to put it. the parking lot lines are either rendering or not, flickering in and out if you will, the attached 2 images should tell the story. imagine these high contrast areas sometimes showing and sometimes not and you get the idea over an animation. is there a clamp or some other way to guarantee that the parking lot lines all render correctly?
    Thanks!
    The problem you are experiencing is most probably due to low AA settings, causing the sampler to miss the thin lines.
    Please try to increase the Adaptive subdivision Min rate.
    Tanya Metodieva
      OK I will increase them, but I was hoping to get away with the lower settings because its all I need. thanks for the tip though!
      Matt
