Render both sides of polys correctly
  • Render both sides of polys correctly
    Hi all
    i have some data where the normals are flipped and I cannot flip them back without ruining the data.
    However, when I render the object in vray the diffuse is not rendering correctly, it renders much darker.
    I know you have the " reflect on backside" button for allowing reflections on the backface normal ( which works on the data fine) and I know about the "double sided" button which is ticked and should allow me to render correctly on both sides but it isnt.
    Am I going wrong or missing something. I can upload picks and maya files if needed but Im guessing this is an obvious one ?
    Will.
    you can maybe try vray 2 sided material?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Make sure this is checked?
      http://www.spot3d.com/vray/help/maya...ial_params.htm
      Maya 2020/2022
      Win 10x64
      Vray 5
        Perhaps this helps. Take a look:
        http://www.spot3d.com/vray/help/maya..._globalops.htm
          Hi guys, thanks for the replies
          However what has been suggested hasnt helped and it seems very strange that it renders correctly during the lightcache but not during the final render.
          I will do some more investigation and try to post some examples.
          Thanks for the replies all the same
          Regards
          Will
