Vray light material and proxies.
  • Vray light material and proxies.
    When I have a proxy with a light material set to direct illuminate, it just renders black. Does anyone know if there is a 1.5 release of Vray that fixes this bug?
    Also if you use the direct Illuminate for a blend material it seems to break as well for direct illum.
    Thanks..
    looks like it does render as a proxy when direct illumination is set to off, but that kind of defeats the purpose of having it on...
      The direct illumination option only works for regular meshes at the moment, since the entire mesh must be available at the start of the frame, whereas proxys are dynamically loaded.
