Urgent! rendering from -minus numbers
  • Urgent! rendering from -minus numbers
    We have a selection of animations which start at -130 up to frame 130 in the time line. So the sequence should start from -130 up to 0 then up to 130 but does vray recognise the minus frames? If you look at the calculated maps as a list it shows -001 as the first frame in the sequence so does vray. this would explain why we cant render out any minus framed animations.
    Thanks
    Or does anyone know a utility to reverse the order and rename the maps so -130 becomes -001?
      Can't you just shift your animation to start at 0?
      Portfolio: http://www.cgifocus.co.uk
        The maps have already been calculated no time to do them again...
          So when vray starts in render mode does it see frame -130 as the first frame and not -001 as windows exploror does?
            Here's a renaming utility that can do just that fine.
            Make sure you sort things right and have it re-enumerate the sequence for you
            http://www.neuhaus13.com/download.php?file=100
