error message
  • error message
    Any idea what this error means when sending .vrscene to render via cmd prompt?
    V-Ray core version is 1.80.01
    Loading plugins from "C:\Program Files\Autodesk\Maya2010/vray/vrayplugins\vray_*
    .dll"
    88 plugin(s) loaded successfully
    Reading scene file "V:\VR_SCENE\build_01_R.vrscene"
    error: Error in file "V:\VR_SCENE\build_01_R.vrscene", line 25: expected a ";" a
    fter property definition
    Closing log - 1 error(s), 0 warning(s).
    Look at the specified line in the .vrscene file - there might be some odd text there. Is there any reason you are using such an old version?
      old version thats interesting let me dig deeper on that..I thought I had latest build from about a week ago
      here is the test on line 25
      rgn_left=-1.#IND;
        Hm ok; it will work if you replace "-1.#IND" with "0" for example; newer builds should handle this without problems.
          OK I installed the latest nighlty and has fix it, I dont understand why it was an older version as I keep up to date with the latest builds within a week or so.
          Thanks for your help
            One more question, if I have calculated my vrmaps then go back to the scene and change a maya shader to a vray shader on an object (same texture file)then send the scene to render would the new shader change invalidate the vrmaps?
              It should be fine.
