Batch render error
  • Batch render error
    well I might have made a mistake by upgrading my workstation vray to the latest nightly build. im getting this strange error on render.
    Error: Not enough data was provided. The last 0 items will be skipped.
    any clue what this is or caused by. its the only error in the log before maya exit with status 210.
    this looks like maya error...when does it happen during rendering? also if you try a simple scene does it also occur?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      its possible, although I did upgrade to the latest nightly build on friday minutes before i launched this render. however i do get this error on my workstation which is upgraded to the latest build so i suspect its not necessarily a compatibility issue with the new/old versions of vray because of this. I have not tried it on a simple scene yet. will get back to you when i can do some more test.
        yep ok my bad was a general error in the maya scene due to a naming conflict of objects. sorry for assuming Vray was the culprit. happened to coincide with an upgrade so I got nervous. foot in mouth.
