We have a problem in production right now where using vray smoothing attributes to smooth objects at rendertime is causing renders to hang indefinitely... Could be while it's loading textures, can be during prepass, can be during render, sometimes right after it says "starting 8 threads" or whatever.. But render will just hang and take up tons of memory, but not fail directly, so our farm can't recover from it without a user noticing the problem. This is a big problem, we need these shots out. For now we will turn off smoothing and switch to using maya mesh smoothing, but this wasted days of rendertime.
vray smoothing attr's making renders hang
Maybe it did, I did look around + search and only saw threads about adding the attributes and such. is there a place where the effects of dynamic memory limit are discussed? I see a short blurb about it in the support but I wonder if there is more aspects to it.
Thank you for the quick reply, I didn't know it was a wide-spread issue. Still, if it's so common, maybe something more obvious could be put in the log for it?
Also it took me until I posted this thread to understand that the threads are in backwards order from most forums. This place is really hard to read for someone just popping in for a moment.Last edited by SteveMack; 10-09-2010, 06:07 AM.
Originally posted by SteveMack View PostAlso it took me until I posted this thread to understand that the threads are in backwards order from most forums. This place is really hard to read for someone just popping in for a moment.
VladoI only act like I know everything, Rogers.
I really didn't mean to sound like a jerk. This is a common issue, and represents a significant portion of problems reported here. Perhaps simply upping the default Dynamic Memory Limit would be good. 500 is awfully low, and will often run people into problems. We have presets that up it to 6000 by default. We can assume most people have at least 4 gigs of ram to devote to rendering? Perhaps a better default would be 2000? This might result in fewer general complaints. In your case Steve, that would still be too low, but at least it would reduce the issue.
From postings I've heard from Vlado in the past, it looks like that feature will be getting some improvements in performance, so it may be moot to think too much about it right now.
Took me a few times here to get used to the forums too. I did switch ordering in my prefs, and am much happierAnd no, it was not in the post just before this one. I think it was in another section altogether. So sorry.
Andrew
No worries, it's just a bit frustrating as a TD with no VRay experience trying to help my lighters figure out what the hell is going on with a new render engine and we have a fairly unique pipeline, it can be hard to pin down where a 'bug' is coming from. Some hiccups are expected, tensions are running a bit high because of a deadline that we don't have time to render for, so any failure is going to sound like OMGCATASTROPHE
We will play around with the mem limit a bit and see what works. However, one thing I don't understand is how this affects the memory usage on the system. When a scene is rendering on a workstation with the Maya gui, it takes up 8-9 gigs of ram, when I render via command line batch, it just thrashes... Am I supposed to set my mem limit to 8-9 gigs, or..?
We are thinking of a different default value for 64-bit builds; since SP1, setting the limit to 0 means no limit at all and V-Ray will take as much RAM as it needs. Other than that, 2 or 3 GB below the physical memory in your system is often a good value.
@SteveMack
Just like you, I'm also putting vray through it's phases for the first time in production. I would be very interested in hearing about your conclusion on this matter as I'm sure I will find my self in the same spot in the near future. so maybe after you have compleated your project, would you mind posting your experiences? Like if upping the dynamic memory limit fixed your problems and so on.
Thanks
Marre
Something else to keep in mind: V-Ray will by default subdivide the mesh up to 8 times (max. 256 subdivisions along a triangle side), depending on its distance to the camera; often it's not necessary to go this high though.
Originally posted by vlado View PostWe are thinking of a different default value for 64-bit builds; since SP1, setting the limit to 0 means no limit at all and V-Ray will take as much RAM as it needs. Other than that, 2 or 3 GB below the physical memory in your system is often a good value.
We've been trying to test setting the dyn limit to 0, however Maya's render globals / the vraySettings node won't take values outside of the 5-20000 range (build 12190).
Is there a specific build number where this took effect?
Thanks,
Trey
