AO option can't find it
  • AO option can't find it
    As I can remember there was option for activating AO, but can't find it anymore, is that out?
    - H -
    There is the VRayDirt texture - is this what you need?
      No, I might mix it with 3dsMax options... This is from 3dsMax help:
      Ambient occlusion
      These controls allow you to add an ambient occlusion term to the global illumination solution.
      On - enable or disable ambient occlusion.
      Amount - the amount of ambient occlusion. A value of 0.0 will produce no ambient occlusion.
      Radius - ambient occlusion radius.
      Subdivs - determines the number of samples used for calculating ambient occlusion. Lower values will render faster, but might introduce noise.
      - H -
        Yes, it's a 3ds Max thing for now; will be adding them to the Maya builds shortly.
