Light_Select elements don't work with lightSphere
  • Light_Select elements don't work with lightSphere
    Vray linux64 build from 24 september.
    When you create a light select element with light sphere connected (image format exr), the image is wrong (multicolor like rainbow ahah).
    Is it possible to fix this ?
    I am in production.
    Thank.
    www.deex.info
    Do you have a scene for this? Works fine for me here on a simple test.
      OK here the scene.
      Look all lights select elements (diffuse type).
      There is SSS2 material on spheres.
      Linear workflow.
      With texture, it is more ugly.
      http://rapidshare.com/files/42100960...tSelect.ma.zip
      www.deex.info
        So, do you have the bug ?
        www.deex.info
          Yes, it appears to be because of the "Cutoff threshold" parameter of the lights; if you set it to 0.0 it will be fine. I've made a note to fix it though.
            Thank you Vlado !
            www.deex.info
