Max CPU won't load on renderfarm.
  • Max CPU won't load on renderfarm.
    I have a scene that is filled with all proxies that are referenced and the CPU's can't load to 100 percent on the farm. Is there a bug when referencing proxies that I do not know about?
    Non proxy scenes with no referencing render at Max CPU across 8 cores.
    I think I found the issue.. Not sure though.. If I have 20 Referenced Proxies, it looks as if it is loading the same texture into ram causing me to run out of memory.
      Strange.. My render takes 7 minutes locally using the render view, but 50 minutes to 1.5 hours on our render farm. Is there something I should check Vlado? Is the Vray translator broken in Build 12398 Maya2009 X64 Linux?
