When I cmd line render multichannel exr's the delimiter before the frame number is omitted. I can compensate by appending it to the fileNamePrefix in the VRay common tab of render settings, but it would be better if it worked like normal exr renders.
multichannel exr missing delimiter
Yes, there is a bit of a mismatch here (multichannel .exr files go through a different code than regular ones); I'm somewhat hesitant to fix it at this point as the code is shared with V-Ray for 3ds Max and might break existing workflows. Will see what can be done about it.
