Camera mapping (projection file) in a VrayLightMtl color crash Vray.
  • Camera mapping (projection file) in a VrayLightMtl color crash Vray.
    Like the title : if you connect a file node (bitmap) in 3D projection with a camera in the color slot of a VrayLightMtl, Vray will crash.
    Build 24 september Linux64.
    www.deex.info
    Is this with the "Direct lighting" option enabled?
      Yes, it is !
      www.deex.info
        Ok, I believe this is fixed for newer builds.
          Ok, i just installed the 15 october build.
          It is working but now i found an another crash : if you connect a file bitmap in a VrayLightMtl color with the "use image sequence" enabled (of the bitmap file), Direct lighting enabled, with motion blur enabled, Vray will crash.
          When you activate motion blur, Vray crash.
          Build 15 octobre Linux64.
          I must render my shot with motion blur...
          www.deex.info
            Is it hard to fixe this bug ?
            www.deex.info
              No idea yet; can you get us a scene that crashes, however simple, to vraymaya@chaosgroup.com?
                I sent the scene.
                Please say me if you have the crash.
                Thanks.
                www.deex.info
                  Hi Vlado,
                  Do you have the scene ?
                  www.deex.info
                    Yep, we can reproduce the issue here and we will fix it. Thanks a lot!
