I've been sending some shots to the farm from the Nov5th build. The farm is on the Aug24th build.
It has failed to render the selected camera. I set the camera in the vrayCommon tab, but that camera refuses to render. Instead, it appears to render cameras that are shape nodes under lights. (I use view through light a lot).
So I went and deleted all camera shape nodes in my scene other than the renderable main camera. selected that camera in the Common tab, and it still rendered the persp view.
The only way for me to get the correct camera to render was to edit my submission in Deadline to force the correct camera.
So, I'm guessing you're fiddling with getting "renderable" cameras to function. Personally, I would not push that feature, as we don't need it... but I'm sure you're getting requests
Andrew
Andrew
