2 environmentOverrides after another only takes first environment override
  • 2 environmentOverrides after another only takes first environment override
    Hey Gang,
    i have a transparent object and one solid obj inside of it. Both objects need different reflection environments. Seems that only one EnvOverride is supported at the moment.
    See the pictures and the attached scene here:
ID:	872418Click image for larger version
    doubleOverride.zip
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
    You can use the environment prioriy option to specify which environment override takes precedence in this case.
      hmm...good idea, but it does not seem to work..i am on build 13606....i tried setting the prio to 2 and 3 and tried vice versa, but it always showed up wrong...u can try it in my testscene from the 1st post
