displacement on proxy
  • displacement on proxy
    I have a problem where the proxy does not displace the material at all.
    im using this build
    [2010/Dec/6|10:04:11] V-Ray: V-Ray for Maya version 1.50.SP1 from Sep 15 2010, 08:26:35
    http://i245.photobucket.com/albums/g...bb/spheres.jpg
    sphere on right is original, sphere on left is the proxy. when create the proxy it will add that grey shader ball connection and create a new shading group. so it makes sense that it doesnt displace but then I try to add displacement to the proxy shading group. no dice. any clues?
    Best,
    bradon
    Once you export something as a proxy it is no longer modifiable in any way (except for changing its position/rotation/scale in the scene).
    It may be possible to rework this a bit to support displacement and we are looking into it, but for the moment you will have to render the original geometry or bake the displacement before exporting.
      oh wow. that's a bummer.. I always thought you could. Thanks for letting me know though so I don't keep trying!
        Any news ?
        We can not bake the displacement before to convert to a proxy because we use a noise, and the noise in Vray in not the same that Maya. So when we bake the displacement, we haven't the same result that when we use directly the same noise in Vray...
        www.deex.info
          Bring your model into Zbrush and displace until you bleed. Then export the highest detailed obj and make a proxy.
            Too complicated :
            1) We have a lot of models.
            2) All models are animated.
            Convert a model in Maya (displacement to polygon with history for animation) is not enought precise, and we haven't the same result.
            www.deex.info
              And we can not work/animate/setup a model with a lot of polygons...
              www.deex.info
                Check this out.
                http://www.lightstorm3d.com/
                  Or this : http://www.hajimenakamura.com/hajime...isplaceD.shtml
                  www.deex.info
                    some sweet shit!
                    PLAY
                    www.kriscabrera.com
                    kris@kriscabrera.com
