frame stamp filename field always says "untitled"
  • frame stamp filename field always says "untitled"
    Is there some where I need to set a value to make it work? I was hoping to get the scene name printed on the render.
    "filename" is using the name of the vrscene file, so if you set that, you will have it printed in the stamp.
    Is that what you're looking for or you would expect that to be Maya scene name?
    V-Ray for Maya developer
      Yes, in the VFB I would expect it to be the name of the maya scene file.
        Thanks for the quick reply. It will be changed in the tomorrow's build.
          Hey everybody. Are chaos group the best devs or what?!
          Thanks Milena!
            Thanks Milena!
            Definitely.
            people don't believe me when I told them how quick Chaosgroup is.
              Thank you for the kind words, we really appreciate them
                Just a quick update on the issue and the requests I got as PM.
                In tomorrow's build you can find the following changes in the VFB frame stamp:
                - "filename" is the full path to Maya scene name
                - "scenename" is just the scene name
                - "renderlayer" is the current render layer
                Let me know if you find everything working as expected
                  Yes, everything as expected
                  Thanks again for the very fast response.
                    Thanks a lot for the feedback!
                    Closing the issue then
