Noisy diffuse reflection
  • Noisy diffuse reflection
    we have a problem with a diffuse reflecting metallic board.
    Please take a look at this image:
    http://upload.sequenz.com/vray/seq101209.jpg
    As you can see the metallic board in the middle looks fine at the bottom, but very noisy at the middle/top area, where a diffuse reflection of a window with a Skylight Portal (Subdivs 40) light can be seen. Why is it so noisy there?
    Using Maya 2011 SP1 under Win 7 64bit and the NB from 06th december.
    Sampler Adaptive DMC with 2/20 and 0.01, IRmap + LC, Adaptive Amount 1.
    VRayMtl had a diffuse colour of dark grey, Brdf Type Ward, Reflection colour v=0.76,
    Amount=0.76, Reflect Glossiness = 0,871, Subdivs=40, Fresnel on, IOR 16.
    Using Sun+Sky as environment.
    Any hints?
    TIA
    Lars
    You can try reducing the Noise threshold for the Adaptive DMC sampler; 0.01 may be too high - something like 0.005 or 0.003 may work better.
      Thanks Vlado. How can I forget the threshold!? 0.005 seems to do the trick.
        Or if possible a reduce noise filter in post production
          We had tried that, but the results were not satisfying. So we decrease the threshold. Wish we could double our render capacity
