syntax error in velocity script ',' must be a '.' ??
  • syntax error in velocity script ',' must be a '.' ??
    I'm am getting this error when using a velocity render element:
    Error: setAttr vrayRE_Velocity.vray_max_velocity_last_frame 3,074068;
    Error: Syntax error
    the , should be a .
    has this been fixed in newer builds than mine (see sig)?
    showreel: http://vimeo.com/27236919
    Do you have "," set as the decimal symbol in the Windows regional settings?
      I'm on osx.. but in maya a . is regarded as a decimal symbol..
        What about outside Maya?
        Best regarsds,
          aah.. but that was it, I was wondering why only 1 machine was giving this error
          this machine has it's decimal symbol set to ','
          my machine has it set to '.'
          thanks
            Ok then; thanks for the pointer, will try to fix it.
              I made a quick fix today that hopefully is enough, should be available in tomorrow's build. Hope that helps.
              V-Ray for Maya developer
                wow great thanks!
