creating vraySettings node
  • creating vraySettings node
    I couldn't find the answer to my question in the forum. Please excuse me if it's there but I missed it.
    I'm having a problem with a script that opens a new scene, does some things and renders in VRay. The problem is that the vraySettings node doesn't exist in a scene until vray is selected as renderer ¿manually?.
    I'm using the command setCurrentRenderer vray but this doesn't create a vraySettings node just jet so when I try to set the render params y get a "setAttr: No object matches name: vraySettings.fileNamePrefix" error...
    Any help would be greatly appreciated
    Cheers,
    Alberto - El Ranchito Imagen Digital
    You can use the vrayCreateVRaySettingsNode() MEL procedure; it will check if a V-Ray settings node exists and if not, will create one.
      Great! Thank you!!
      Is there a place where I should be looking for this kind of info?
      Bests!
