Urgent shader export issue
  • Urgent shader export issue
    I'm trying to export a shader from one scene and import it into another. When I import it and render I get a much darker result. Also the shader swatch is darker. If I import that same shader back into the scene it came from, it works fine.
    I'm trying to debug this, but so far without any luck. Anybody experienced anything similar or have ideas to what could be wrong?
    Also, how much is render global settings affecting the shader swatch?
    Thanks
    Marre
    Seems to be a gamma issue. Did you make sure the settings in the color mapping are the same in both scenes and the sRGB button in the framebuffer is set equally?
      you are correct! I had all the gamma settings correct, but I did forget the little checkbox "affect swatches". The scenes I was importing to had a darker light setup too so it got a bit confusing for me...
      Thanks for your quick reply!
      Martin
