can't find MEL command to switch texture baking on
  • can't find MEL command to switch texture baking on
    I have this batch bake script that's part of my V-Ray Tuner script but one thing I can't figure out how to get working is how to switch texture baking on as a MEL command (the dropdown attached). If someone can tell me what the command is, that would be great.Click image for larger version
Name:	Screen shot 2011-04-03 at 12.10.54 AM 1.png
    Dave Girard
    I'm not in front of my machine right now, so I can't check, but it should be an attribute of the vraySettings node.
      Hello,
      Not sure which of the following you need, but here you go:
      That will change the selected item in the drop-down menu:
      optionMenuGrp -e -sl 2 vrayBakingEngineCtrl;
      The following will set the baking render:
      setAttr "vraySettings.bakeRender" 1;
      This is another setting you may need:
      setAttr "vraySettings.sh_export_on" 0;
      And these are for the interface - to enable other controls:
      attrControlGrp -edit -enable true vrayBakeChannelCtrl;
      attrControlGrp -edit -enable true vrayBakeDilationCtrl;
      attrControlGrp -edit -enable false vraySphericalHarmonicsOptions;
      You can see what happens when you change the selected item in that drop-down menu in vrayCreateCommonGlobalsTab.mel
      Hope that helps. Let me know if there is anything else you need.
      V-Ray for Maya developer
        thanks - that did it.
        Dave Girard
