Vray Beta 2 build crashing consistently on Distributed rendering on farm
I can but it stalls out and tries to rerender the frame after reporting that the crash was an error which causes the frame to immediately start over until a non crashed version of the frame goes through.
The other issue is that sometimes the frame doesn't complete entirely on the vrimg write and one or two of the channels (usually the multimattes) come out partially corrupted.
Just tried another setup..stripping all of the Shave and a Haircut data out of the scene and limiting all the textures...I was hoping that maybe the error was on the shave side of things causing the crash...looks like that's not the case.
The only other thing I think that may be crashing the render is the light cache.
I'm going to send off a job where it is disabled, see what happens.
Does the fact that each of the render nodes are dual 12 core hyperthreaded xeons have any potential issue (the idea being that the light cache threads may screw up past 16?)
For continuity sake I've attached the error from the shave free attempt
Error Message
Exception during render: An error occurred in RenderTasks(): Deadline caught error "Error: There was a fatal error rendering the scene.". If this error message is unavoidable but not fatal to your render, please email deadline-support@primefocusworld.com with the error message, and disable the Maya job setting Strict Error Checking.
at Deadline.Plugins.ScriptPlugin.RenderTasks(Int32 startFrame, Int32 endFrame, String& outMessage)
Slave Log
2011/Apr/12|10:27:28] V-Ray: SD triangles: 2772
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray: MB triangles: 0
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray: Static primitives: 951878
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray: Moving primitives: 0
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray: Infinite primitives: 1
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray error: There was a fatal error rendering the scene.
0: STDOUT: Error: There was a fatal error rendering the scene.
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray: Render interrupted
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray: ========================
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray: Clearing exporter memory...
0: STDOUT: Writing crash dump to "C:\Users\User\AppData\Local\Temp\VRayMaya.dmp "
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray error: Fatal error freeing exporter memory.
0: INFO: Deadline is ignoring error: "Error: Fatal error freeing exporter memory." because plugin setting Strict Error Checking is enabled and this error is not usually fatal.
0: STDOUT: Error: Fatal error freeing exporter memory.
0: STDOUT: [2011/Apr/12|10:27:28] V-Ray error: Fatal error rendering image.
0: INFO: Deadline is ignoring error: "Error: Fatal error rendering image." because plugin setting Strict Error Checking is enabled and this error is not usually fatal.
0: STDOUT: Error: Fatal error rendering image.
0: STDOUT: Scene C:\Users\User\AppData\Local\Prime Focus\Deadline\slave\jobsData\SCN_01_06_C01_NOSHAV E.mb completed.
Scheduler Thread - Render Thread 0 threw an error:
Scheduler Thread - Exception during render: An error occurred in RenderTasks(): Deadline caught error "Error: There was a fatal error rendering the scene.". If this error message is unavoidable but not fatal to your render, please email deadline-support@primefocusworld.com with the error message, and disable the Maya job setting Strict Error Checking.
Error Type
RenderPluginException
Error Stack Trace
at Deadline.Plugins.Plugin.RenderTask(Int32 startFrame, Int32 endFrame)
at Deadline.Slaves.SlaveRenderThread.RenderCurrentTas k()
I THINK that its been figured out.
Metzger and I went through things piece by piece and I managed to get a consistent render out of the box.
It looks like a bug with the scene referencing.
By creating the scene from scratch and redoing all referencing things seemed to render.
I won't really know until tomorrow when the farm parses the scene but here's hoping that maybe it will get through.
Is there a fix planned soon? When I DR Render with my farm, Maya is hanging at the end...VRay Frame Buffer hanging...need to restart Maya...
Works without the VFB, but I want to use it for the render elements...
