Vray 2.0 running under Maya 2011.5
  • Vray 2.0 running under Maya 2011.5
    Hi guys, I need to finish a little work before update to Maya 2012, but the question is: How can I do run Vray 2.0 in Maya 2011 Subscription Advantage Pack?.
    Searching in the forum, I saw the way to do it, but with Vray 1.5, the next process:
    Install Vray for Maya in the next three directories:
    a)Suscription Advantage Pack Maya's root
    b)Suscription Advantage Pack Maya's root/vray/plugins
    c)ChaosGroup's root folder.
    Then, copy "modules" folder, from prior installation to the root of Maya 2011 subscription advantage pack and edit the file leaving "VRayForMaya.module as:
    // Module file for Maya. Helps Maya find resources for VRayForMaya.
    + VRayForMaya2011x86 0.9 C:\Archivos de programa\Autodesk\Maya 2011 Subscription Advantage Pack/vray
    For the last, establish next environment variables:
    VRAY_FOR_MAYA2011_MAIN_x86, C:\Archivos de programa\Autodesk\Maya 2011 Subscription Advantage Pack/vray
    VRAY_FOR_MAYA2011_PLUGINS_x86, C:\Archivos de programa\Autodesk\Maya 2011 Subscription Advantage Pack/vray/vrayplugins
    Finally, launch Maya and find vray plugin, throught plugin manager in (mayaroot/vray/plugins).
    All right, but I still continue having this error:
    // Error: Cannot find procedure "vrayUpdateAE".
    What am I doing wrong!?.
    Hi Reaversword,
    We have a build for Maya 2011.5 (subscription advantage pack) for Windows 64bits in the nightlies.
    And we can build versions for the other OSes, if there is a demand for them.
    Please write to vlado@chaosgroup.com and state the version of OS and Maya you're using and you'll get a working version of VRay 2.0.
    Teodor
    V-Ray developer
      Ok, t.petrov. I'll do it. It's for win32 (and for the gods, a month waiting for receive my new machine yet...)
        Unfortunately we don't have a 32-bit version; it looks like the Maya 2011.5 is no longer available from the Autodesk subscription center so we can't get its SDK. I will ask if we can get it, but it might take a while.
