Quick question. When I setup V-Dirt texture on a surface material, then adjust the y bias and distribution and swap the occluded black with unoccluded white, it doesn't render correctly. I actually have to use a maya reverse node on the V-Dirt to get the correct inverse color for the V-Ray Dirt texture to use as a matte.
It's been like this for a long time. Is there possibly a bug with it?
Here is the V-Ray Dirt result on a light material.
IMAGE 1
Here is the same settings but with the colors swapped in V-Ray dirt.
IMAGE 2
And here is the V-ray dirt with a maya reverse node. To me, this would be the correct result. But I am sure you might have a scientific explanation why image 2 would be the correct inverse. :P
IMAGE 3
MAYA SCENE
http://www.megaupload.com/?d=91NRZ1PK
Thanks!
-Scott
IMAGE 1
IMAGE 2
IMAGE 3
MAYA SCENE
Thanks!
-Scott
