Vray attributes in AE not showing
  • Vray attributes in AE not showing
    I have constant problems in Maya 2012 and Vray 2.0 with Vray attributes not showing in AE. For example Vray Camera attribute is shown when I add it. But if I close AE and open it later I can access Physical camera attributes only through Extra Attribute and that is really messy ...
    Does anyone else experience this?
    - H -
    Have the exact same problem... sometimes the attributes are even greyed out.
      In addition to that occasionally it causes crashes, but I am not sure if this is Vray or Maya related.
      - H -
        I noticed this as well; will be looking into it.
          2012, same here, but not intermittent and effects all custom attrs. No 'pretty' attrs show. Just stuff under extra. Somehow the AE template isn't publishing correctly.
          Edit: Ok, it's intermittent?? Works fine on restart.
            What version of Vray are you using? There is a fix in that regard from late May.
            Please, let me know if you're still having issues with later versions.
            Thanks,
            Milena
            V-Ray for Maya developer
