maya segfault with vray2
  • maya segfault with vray2
    Hi
    I have a clean maya2012hotfix2 install and I just installed vray2.0 on my linux machine.
    When I lunch maya I have this segmentation fault :
    [2011/Jun/3|14:52:10] V-Ray: V-Ray for Maya version 2.00.04 from Apr 28 2011, 02:18:07
    [2011/Jun/3|14:52:10] V-Ray: V-Ray core version is 2.00.01
    [2011/Jun/3|14:52:10] V-Ray warning: Loading shaders failed: no <*.txt> files in .
    [2011/Jun/3|14:52:10] V-Ray error: Could not register VRayGeoSun (kFailure): Unexpected Internal Failure
    registerTransform failed: (kFailure): Unexpected Internal Failure
    maya encountered a fatal error
    Signal: 11 (Unknown Signal)
    Fatal Error. Attempting to save in /usr/tmp/user.20110603.1452.ma
    Segmentation fault
    Thanks in advance.
    Something seems to have gone wrong with the installation; what is the value of the VRAY_FOR_MAYA2012_MAIN_x64 and VRAY_FOR_MAYA2012_PLUGINS_x64 environment variables?
    Sometimes you may need to log out and log in again for the changes to these variables to kick in.
      Hi vlado.
      I don't have those variables. I only have the 2011 ones, but I didn't reboot yet. Setting the variables manually works fine, so I suspect that after the reboot it will work.
      Thanks.
        You don't have to reboot the whole machine, just log out and then log in again.
        V-Ray developer
          Ok. Thanks
          It's working...
