Focus distance makes image darker when set under 10 units...
  • Focus distance makes image darker when set under 10 units...
    hi,
    ive a prob with focus distance and lower values than ca. 10 units..
    When I render the scene without DOF everything is ok.
    Than I switch on DOF with specify focus on too.
    When I use a focus distance from 25 units or more, everything is fine too.
    No changes in brightness.
    (higher values are fine too)
    When I set focus distance to 5 units, the result becomes much darker.
    The scene units are centimeter.
    Maya2011, vray 2.004, Win7
    Its a big prob for me, because its not posible to rescale the whole scene in this case.
    Is this normaly?
    What can I do?
    Thanks for help
    Vray 3.5, Win10
    www.3dcompani.com
    no ideas?
    I made a little testscene to show the prob clearly.
    Simply load the scene and start RT engine.
    Then scroll from frame 1 to frame 75 and ull see what happens.
    For me its a big prob in my actual project, because most take have less than 10 units foacal distance.
    I can understand, that phys cam makes it darker, when zoom is the theme.
    In real it is the same.
    But when I simply fly more near to an object I cant see any reason for massive brightness changes!
    What can I do?
    Vray 3.5, Win10
    www.3dcompani.com
      I have the same problem...
      Ivan Tiunov
      Red Screw + Production
        We added this issue in our "to do" list.
        Thank you for your feedback.
        Zdravko Keremidchiev
          thats great.
          thanks for response
          Vray 3.5, Win10
          www.3dcompani.com
