No mask for Tiff format
  • No mask for Tiff format
    This is in Maya2011 SP1, VRay for maya 1.5SP1 Nightly Build 14259, Windows 7 64 bit.
    We use this kind of command line, to be sure the tiff format is used :
    render -r vray -of tiff .....
    Problem : only the color is written, no mask at all (not just black, the mask channel does not even exist in the written tiff file).
    I also tried "-of tif" instead of "-of tiff", and also I set "tif" inside the Render Settings, always the same problem.
    (it works all right for sgi or tga)
    How do you activate the mask for tiff format ?
    Thanks.
    Thanks for the pointer; will look into it.
      you are correct, V-Ray currently doesn't support writing out the alpha channel in TIFF files. We've added this issue to the bug tracker and it will be fixed soon.
      Veselin Georgiev
      Developer
      Chaos Software, Ltd.
        Thank you !
