Animation mode reset button
  • Animation mode reset button
    To what relevance is the stored samples in memory to the saved IR maps. Once the maps are created and your in animation mode can the reset button be pressed?
    Am I right in thinking it's just for the prepass mode so can be reset before rendering mode is set.
    So what use is the save button if the samples in memory have nothing to do with map creation and cant be used for prepass or rendering modes.
    Some one put me straight...please.
    The save button is useful if you want to use the incremental irradiance map mode to calculate the map from several angles, and then save it to disk (there is also a MEL command to do that).
      Ah thank you Vlado.
      are you going to revert to our wxWidgets code for Maya 2012 rather than Qt for v.1.5?
        Originally posted by stezza View Post
        Ah thank you Vlado.
        Yep.
