I'm runing 2.00.04 on win7 64bit, maya 2011.5. Sun and sky is totally burned out on default settings. Loading an older version renders correct. Is this a known bug?
in march it was a thread too..
here the hint from t.petrov...
The old VRay have been adjusting the sun's intensity, when there was no physical camera in order produce almost correct results.
These mechanism is removed, because it causes problems in RT.
You'll get the same result if you multiply the sun's intensity by 0.0625 manually.
and from Vlado...
Yep, as Theodor pointed out, in older builds the sun intensity was artificially reduced when rendering from a non-physical camera. However this hack caused some other issues and we eventually removed it.
