Is "pure virtual function call" on a DR a memory related error?
  • Is "pure virtual function call" on a DR a memory related error?
    HI there, on my DR slaves I get this error message when the scene is generating its light cache:
    Building light cache...: 10.55% [ 0h 1m 45.3s] [ 0h 14m 52.4s est]
    Building light cache...: 20.63% [ 0h 1m 47.7s] [ 0h 6m 54.4s est]
    Building light cache...: 30.96% [ 0h 1m 49.3s] [ 0h 4m 3.8s est]
    Building light cache...: 40.35% [ 0h 1m 50.7s] [ 0h 2m 43.7s est]R6025
    - pure virtual function call
    It seems to reset by itself then try and attempt a render again:
    Building light cache...: 10.70% [ 0h 1m 50.6s] [ 0h 15m 22.5s est]
    Building light cache...: 21.19% [ 0h 1m 52.8s] [ 0h 6m 59.5s est]
    Building light cache...: 30.16% [ 0h 1m 54.2s] [ 0h 4m 24.5s est]
    Building light cache...: 40.67% [ 0h 1m 55.9s] [ 0h 2m 49.0s est]R6025
    Like a never ending loop. The main rendering machine completes this fine (x64 whereas the slaves are unfortunately 32bit).
    If it is a case of memory I've set my memory limits to 3000MB as to keep up with the 32bit machine, but I guess it is still running out? Are there any other options I can play with?
    Maya 2020/2022
    Win 10x64
    Vray 5
    It's not related to memory as such; can you tell me which V-Ray version you are using? Can you get us a scene where we can reproduce the error?
      Hi Vlado, thank you, I'm using this version of Maya 2012x64 with Win7 x64.
      [2011/Jul/28|09:13:04] V-Ray: V-Ray for Maya version 1.50.SP1 from Jun 20 2011, 19:10:46
      [2011/Jul/28|09:13:04] V-Ray: V-Ray core version is 2.00.01
      The slaves are on the same version of V-Ray but obviously Win7 32bit and Maya 2011 32bit.
      I can try upload a scene but it is quite heavy which I thought it could be a memory error. I'll see if I can strip some stuff out and send it in to your email. If I do I'll reply below and try and send it in. Thanks!
      Maya 2020/2022
      Win 10x64
      Vray 5
        Hi Vlado, I've narrowed it down to a particular referenced scene.
        Unfortunately the parent and child scenes are too complex to send it and when I strip it down it renders fine...d'oh!
        At least this is a clue. There is nothing unusual about the scene but it is physically large ([2011/Jul/28|13:03:48] V-Ray warning: Scene bounding box is too large, possible raycast errors.) and contains proxies that are scattered around.
        If I discover anything else I'll post back here.
        Maya 2020/2022
        Win 10x64
        Vray 5
          Final update, sorry for the multiple posts. But this one is definitely memory related in the end.
          Maya 2020/2022
          Win 10x64
          Vray 5
            Well, it may happen when you run out of memory, but still, it shouldn't happen and I think it's a bug - which is why I wanted to take a look at the scene
