[VFBCore::SetRegion] Error writing render region to raw image file.
  • [VFBCore::SetRegion] Error writing render region to raw image file.
    I'm trying to render an animation but this keeps on popping up with Maya 2011x64, Win7x64 and V-Ray SP1 from june 20th:
    [2011/Jul/29|14:31:34] V-Ray error: [VFBCore::SetRegion] Error writing render region to raw image file.
    Error: [VFBCore::SetRegion] Error writing render region to raw image file.
    [2011/Jul/29|14:31:35] V-Ray error: Cannot write output image file "xxx/images/cam19_60007.exr"
    Error: Cannot write output image file "xxx/images/cam19_60007.exr"
    It worked for about 6 frames into an animation then decided to stop. However if I look on the server the image in fact has actually successfully rendered but mayaBatch.exe stops with:
    [2011/Jul/29|14:31:35] V-Ray: Render interrupted
    What is this and is there a way to fix this?
    Edit: I noticed this referred to "render region" but I'm sure this is disabled and have never used it in this scene.
    Maya 2020/2022
    Win 10x64
    Vray 5
    check to see if vray frame buffer has render region button pressed in your scene.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Unforuntately that is not the case, it is V-Ray being unable to write to exr for some reason or another. Using a different file format works fine.
      Maya 2020/2022
      Win 10x64
      Vray 5
        Are you writing to a network location? It's a known issue of the OpenEXR library. Storing the images locally or rendering to a .vrimg file will solve the problem.
        @Dmitry - the region rendering issue is long fixed now.
          Aha, perfect will note this one down. Thank you Vlado.
          Maya 2020/2022
          Win 10x64
          Vray 5
            Under what circumstances is this an issue? So far I have had no problems with rendering exr to network folders, but I'd like to be prepared if there are going to be problems.
            thanks
            David
              Its pretty random, seemed to work then all of a sudden got the error message. I htink it might be wise to write to vrimg in future,
              Maya 2020/2022
              Win 10x64
              Vray 5
                I think it only happens if the image takes a really long time to render (several hours).
                  Hi Vlado, it was happening to me with DR and image render times of 1-2 minutes @720P.
                  Maya 2020/2022
                  Win 10x64
                  Vray 5
                    Well, one more reason to use .vrimg then I hope this is fixed for the upcoming OpenEXR 2.0 library...
