plus minus average node -> segfault
  • plus minus average node -> segfault
    I'm connecting a plus minus average to the displacement shader slot, and vray produces a seg fault, what's wrong ?
    "plusMinusAverage2.output3Dx" ---> "VRayMtl2SG.displacementShader"
    V-Ray: V-Ray for Maya version 2.00.04 from Jul 16 2011, 14:08:29
    V-Ray: V-Ray core version is 2.00.01
    [2011/Aug/26|19:03:44] V-Ray: Memory usage: 2.00 MB
    [2011/Aug/26|19:03:44] V-Ray: Rendering image...
    maya encountered a fatal error
    Signal: 11 (Unknown Signal)
    Segmentation fault
    thank you,
    z
    Can you attach a scene here that produces the crash?
      segfault
      You will find my scene attached.
      I noticed that when I switch the plane from vector displace to normal displace it does not crash. Vector displace always crash with this plus minus node...
      Thank you
      z
        I confirm.
        Vector displacement crash vray with a plus minus node.
        Perhaps Vray crash with another "utility node" in vector displacement mode.
        www.deex.info
          The trick is to add a ramp before the displacement node ahaha...
          www.deex.info
            true !
            thanks for the trick !
