motion blur not working
  • motion blur not working
    I have enabled motion blur int he v-ray camera settings and when I do a render i get the following error:
    // Error: There was a fatal error rendering the scene. //
    // Error: Exception [module=1] : Rendering region (448,512)-(512,576) //
    I tracked it down to the tiled EXR image i'm using. When i replace it with a non tiled exr everything is fine. Is motion blur supported with tiled exr's in vray ? Anyone having a similar issue ?
    DId you set your tiled exr to mipmapped in the file node ?
    www.deex.info
      It should be perfectly fine in general; if you can post the scene here or send it to vraymaya@chaosgroup.com it will be very helpful to debug it.
