maya fluids extra attributes
  • maya fluids extra attributes
    I can't seem to find any info in the help docs about the extra attributes for maya fluids when using vray. Also, rendering fluids with vray is extremely slow even compared to
    aya software with the same settings. Vlado can you point me in the right direction?
    You are right that the fluid attributes are missing from the help index - will make a note to add it.
    For the slowness, you need to increase the step size parameter in the V-Ray fluid attributes.
    In any case, we are working a much faster shader for fluids specifically. Right now we are using internally the VRayEnvironmentFog shader, which is very generic and for this reason can be quite slow.
      Good to know ! Thanks !
      www.deex.info
