installing vray on mac osx lion
  • installing vray on mac osx lion
    Im having problems installing as the manual says. when i run the command sudo and the filename of the vray exe i get an command not found.
    i have double checked that im in the right directory and that i have the correct priveliges.
    Anyone that had the same problem and solved it?
    have u tried "sudo ./vray_adv_20004_maya2012_snow_leopard_x64.exe"
    if yes, then what does "ls -al" output
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
      and remember to enable your root user. i think it's in Keychain Access. google root access os x and there'll be tutorials for that.
      /Bard
      www.hellobard.com
      Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
        Hmm, this should not be necessary; I've never enabled the root user on any of our Macs (however my user does have Administrative rights - which may be important).
          really? hmm... maybe it's only for OSX 10.5?
          I did have to enable the root user on a 10.6 machine a few months ago though, it just wouldn't accept the sudo command.
          /Bard
          www.hellobard.com
            ultrasonic. this is what i get from ls -al: -rw-rw-rw-@ 1 albinwikander staff 41316486 Apr 28 03:20 vray_adv_20004_maya2011_snow_leopard_x64.exe
            from what i can see i have the right permissions but it seems like the sudo command just wont work the same way in osx lion.
              Nope...there are execution permissions missing...
              Just do: chmod 755 vray_adv_20004_maya2011_snow_leopard_x64.exe
              After that it should work...this usually happens if u unzip the archives on a windows machine
                thank you ultrasonic! that solved my problem. As you might have figured im not a mac user =)
