Problem rendering instancer with custom plugin input
  • Problem rendering instancer with custom plugin input
    we have a nice tool here which can distribute objects on a surface, without using particles. The tool usses the maya instancer to show the objects.
    Our tool is not using every input of the Maya instancer, we are only using
    "position", "rotation", "scale", "age".
    If I try to render the scene VRay stops with a fatal error.
    Our tool was working with the 1.5 version from VRay. Since we have switched to 2.0... it is not working any more.
    Any idea what could cause the problem?
    VFX Supervisor @ www.parasol-island.com personal website www.dryzen.com latest reel http://vimeo.com/23603917
    Have you tried to export vrscene files both with vray 1.5 and 2.0 and then see what are the differences?
    If your vrscene file is OK, can you send it to us, so we can see what the problem in the renderer is?
    /Teodor
    V-Ray developer
      Here is the 1.5 File, exporting a 2.0 file is not possible
        Then we will need a maya scene file, so we can see why the exporter is crashing/failing.
        Can you give us one? Or this is not possible because you need to give us your tool/plugin/scritp?
        /Teodor
        V-Ray developer
          The plugin is written by the lightstorm3D guys. So it comes with a license and it won´t run on your machine
          I will send you a pm with the email of the guy who programmed the plugin.
          The maya file is attached here.
            The problem should be fixed in the next nightly build. If you don't have access to the nightly builds, please
            send e-mail our support at vraymaya@chaosgroup.com or directly to Vlado at vlado@chaosgroup.com .
            /Teodor
            V-Ray developer
              Big thanks! I´ll check it out asap!
