Hi
I'm rendering animation now and saving files to open exr ( with multi channel ) . The problem is that not all the passes are saved into exr.
When I check with compositing package some passes are missing like : object ID for example ?
Could it be the reason for that when, i Did prepass for animation with moving objects i didn't setup any Vray Extras attributes for objects ID's
I just did it before animation ( rendering) stage, although render element was added from the beginning like object ID etc.
I'm running Vray 2.004 on Maya 2012 ,64 windows vista Ultimate , trying to check render elements in Autodesk Composite package.
greetings
czaps
greetings
czaps
