Unlinked lights still cast shadows
  • Unlinked lights still cast shadows
    We noticed that when we unlink a light the surface still cast shadows. We can remove cast shadows from the mesh but then it wont cast shadows from other lights.
    Is this the intended behaviour or is it a bug?
    /Patrik
ID:	873488Click image for larger version
    What is the version you're using?
    2.00.04 doesn't support shadow linking, but we've added it in the recent nightly builds.
    If you need this feature you can get access to them. Just write an e-mail to our
    support vraymaya@chaosgroup.com or directly to Vlado: vlado@chaosgroup.com
    Then you can use the "Lighting/Shading-> Break Shadow Links" and "Lighting/Shading-> Make Shadow Links"
    /Teodor
    V-Ray developer
      We are using stable build v16302. We tested to break shadow links but it did't work on our build.
      /Patrik
        I think, it is only in the night-nightly builds. The stable ones don't have it.
        V-Ray developer
          Ok! Thanks! It wont be in a stable build until SP1 are released then?
          /patrik
            The shadow linking required some bigger changes to our code, so it would not be safe to port it to the current stable branch, unfortunately. It will go into the next service pack though.
