render artefacts - seeing wireframe?
Can you post that part of the mesh here or send it vraymaya@chaosgroup.com so that we can take a look?
VladoI only act like I know everything, Rogers.
We are seeing this exact same error on the exact same application actually, a beige car inner ceiling!
Is there any solution to this?
We have seen this in a lot of cases before but have always been able to retouch or work around the issue. Now with animation it's a whole different matter...
Our geometry is flawless but as soon as a VRayMtl with a heavy bump comes on the wireframe becomes visible like above. Attached is a freshly created VRayMtl, the only modification is adding a bump texture. The same thing happens when using normal maps.
Max
that really shouldnt happenjust curious your uv's are welded? alternativly have you tried different filtering on your bump texture?
Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Yep, they are welded, and I have tried every type of filtering possible. The problem is even there when using a procedural, so filtering isn't really the fault here.
I also tried creating a new small object matching it to a part of the original and snapped the vertices and UVs by hand, just to have nothing from the old object. Still the same.
I have also tried with and without all kinds of GI, using the DMC sample and the subdivision sampler. I have tried a lot!
Max
what vray build are you working with?Dmitry Vinnik
ShowReel:
I was able to reproduce the issue. If you increase the shadow bias of your light (in my case dome light) it should solve your problem (worked for me anyway).Dmitry Vinnik
ShowReel:
That is something I was bugging chaos a while back.
Basically if u have insaneally tiny bump and a sharp reflections. The bump will break the normal smoothness (in max/maya/MR/Vray as far as I tested) and u end up with faced square/triangle/ngomz ble reflections. Only sollution was to increase the bump tile size (make less tiles I guess)...
Let me know if there is any solution on that issue from chaos side...
Originally posted by vlado View PostDid you send us a scene for the wireframe issue already?
VladoDmitry Vinnik
ShowReel:
