commonTabColumn error
  • commonTabColumn error
    Hi guys,
    does anyone know how to fix/stop this error, I'm using Linux, centos 5.7, with maya 2012
    // Error: setParent: Object 'commonTabColumn' not found. //
    this happens when ever I try to open the maya 2012 render settings, but once I switch to vray tab and back to the common tab it works fine.
    Cheers,
    Anuj
    Did you install V-Ray on the machine, or you load it from a custom location?
      I suppose custom location...a problem that we encoutered too...maybe you should update the docs for arbitrary locations and say that one has to install vray at least once into the correct maya location and "rip out" the 3 modified mel scripts from ../maya/scripts/others and put them somewhere on the network...
      OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
        thanks guys, got it sorted.
        Truly Appreciate.
        Cheers,
        Anuj
          The changes to the scripts are not fatal in any way; the commonTabColumn error doesn't have any bad consequences. In an ideal world, we wouldn't have to modify those scripts, and I hope that we won't have to in a future Maya version.
